Communicating to M400 via CAN
Postby svendsenk on Fri Mar 01, 2013 7:43 am
I am looking to create a data logger using the STM32F407VGT6 Multimedia Board. I have a couple of questions about communicating with the M400.
First is what do I need to set using the ECU Manager.
Next is it possible to change parameters on the ECU such as traction control, and launch control.
Is there a sheet that contains all the message ids and their corresponding meaning.
For hardware connections do I just plug the H and L lines in directly? Do I need any other lines connected. Note my micro will be on battery power so im not sharing power or ground.
Finally has anyone done this with a pic or something else and would mind sending me both their code and circuit diagram.
Any help is appreciated.
svendsenk
Re: Communicating to M400 via CAN
Postby YuriK on Fri May 10, 2013 5:00 pm
You probably should start from watching our CAN related webinars here http://www.motec.com.au/webinars/webinararchive/ they can give you a basic idea about CAN in general and how we use it at MoTeC.
CAN communications in ECU can be configured in the ECU Manager under
Adjust|General Setup|Communications|CAN Setup menu
Regards!
YuriK
Users browsing this forum: Bing [Bot] and 12 guests
