BR2 on 997 cup car
BR2 on 997 cup car
Postby SMR on Mon Jan 07, 2013 7:38 pm
Hello
Im trying to get my Br2 working on a 997 cup car, but i dont have the Orginal ECU in the car, right now no ECU in the car just the ADL2.. Im getting the Br2 to flasch red when i move the BTX in front of it but i cant get the stoppwatch in the ADL 2 to start.. i think its a wiring problem
th
SMR
Re: BR2 on 997 cup car
Postby insomnia on Fri Feb 22, 2013 11:36 am
not sure if i'm right, but i have the same issue for three years.
In my case The Porsche Cup car use a special Firmware and to use or test the BR2
i need to start the engine. In the setup engine must rev over 100 rpm.
Hope this can help you.
Cheers
insomnia
Postby mach1000 on Tue May 28, 2013 4:23 pm
Hi Insomnia,
I know it has been a while since yuo requested an answer, is it still a issue? I have been working with a 997 Cup '09 and '11 and none of them had to have the engine running to check beacon id/running lap time. Do you get a becaon Id in your online data?
Best regards
mach1000
Postby insomnia on Wed May 29, 2013 8:26 am
On the transmitter and the receiver you can choose the channel.
In my case, the little Arrow on the pot was damaged, and i turn both pot in the clockwise
direction to match the same channel. After we test the beacon, and we can see the lap time,
but not the how many laps. To see that the engine need to run.....I cannot say more....
insomnia
Return to ADL, ADL2 and SDL
