LSU 4.9 Connector cut off
Postby Wolfi on Fri Feb 08, 2013 7:11 pm
Hello everybody,
I have a LSU 4.9 Lambda-sensor running on a M800 ECU. To connect the sensor I cut off the connector of the sensor.
After that, I'm uncertain if the resistor which is in the connector plug have any influence in measure the correct Lambda value after calibrate on the air.
In a short way. Can I use a Lamda-sensor which the original connector plug is cut off?
Thanks and greetings from Germany.
Wolfi
Wolfi
Re: LSU 4.9 Connector cut off
Postby Dragon on Fri Feb 08, 2013 11:05 pm
You do not need the resister.
Dragon
