lsu 4.9 connector
lsu 4.9 connector
Postby r.hellenbrand on Tue Mar 17, 2009 10:16 pm
Dear,
I have following urgent problem!
I want to use a BMW LSU4.9 sensor.
I found a Bosch connector (# 1-928-404-669) which fits the sensor.
Now mine problem.
Nobody can tell me the part number from the contacts and seals I have to use.
All I know is that it are AMP contacts.
Does anyone know the part numbers?
Any help is welcome,
Ron
r.hellenbrand
Re: lsu 4.9 connector
Postby Martin on Wed Mar 18, 2009 3:31 am
why not cut the connector and use a Deutsch connector?
The BMW E90`s Drive by wire throttle body connector fits exactly on the LSU4.9.
Postby Scott@FP on Fri Mar 20, 2009 9:41 pm
I believe it is an AMP SSC connector.
To search on the Tyco/AMP website start here http://catalog.tycoelectronics.com/TE/bin/TE.Menu?M=MENU&BML=11177&ID=13981&LG=1&I=13
SSC products are here http://catalog.tycoelectronics.com/catalog/feat/en/c/11392?BML=11177,13981,14998,14016
Select properties on the left side, choose most likely product on right side, view drawing.
Or call Ballenger Motorsports if you are in the US, they stock a large variety of hard to find connectors.
http://www.bmotorsports.com/shop/index.php/cPath/103_108
O2 connectors
Scott@FP
Postby INDYWIRING on Thu Jan 10, 2013 1:03 pm
I know this is an old thread, but I thought this information might come in handy to someone searching the web.
The connector can be found here
http://store.chiefenterprises.com/s.nl/it.A/id.114/.f
The pins are AMP P/N 1241380-2.
http://www.onlinecomponents.com/te-connectivity-amp-brand-1241380-2.html?p=10207522
The seals will vary depending on wire size. I'm using the 964971-1 seals for 24AWG wire. Larger seals are detailed in the attached spec sheet.
http://www.onlinecomponents.com/te-connectivity-amp-brand-964971-1.html?p=10531871
The connector is also available as a kit on ebay or at wb02.com.
Angebotszeichnung (Teil) (28).pdf
Spec Sheet for 1928404669 LSU 4.9 connector
(297.32 KiB) Downloaded 1532 times
INDYWIRING
Postby PQatPIT on Thu Jan 10, 2013 11:06 pm
This company sells all kind of related things, and prices are reasonable. Btw, I'm not affiliated in any way.
http://www.finjector.com/verkkokauppa/client/index/175/
PQatPIT
