Motec M880 for Subaru StI
Postby kisscool on Thu Dec 13, 2012 12:05 am
Hello guy,
My name is Ludovic
i have one Motec M880 and i want use on my Subaru Impreza
My motec M880 option is advance function, lambda and logging 1mb
I have some question about the system.
I want use Std Coils from subaru, I need to connect Ignition module Bosch 0227100211 or i can connect directly the std coil?
What is difference between software manager v23 and software manager v35? what is the best for i use with my car?
in adavnce thank you very much
best regards
ludovic
kisscool
Re: Motec M880 for Subaru StI
Postby Dragon on Sat Dec 15, 2012 2:02 pm
Which Subaru have you got?
If they are coil on plug type, you can drive them directly from M800.
V35 is the one to use.
Dragon
Postby kisscool on Mon Dec 17, 2012 6:00 am
Thank you very much for your answer.
My subaru is STi V7 and i use standard coil from Subaru parts
kisscool
Postby kisscool on Mon Dec 17, 2012 7:04 am
CAn i connect directly to ECU M880 EGT sensor or i need to connect to small box with analog output 0-5v?
I have GPS module and dashboard from 2D datarecording, can i connect directly to Motec M880?
how to do for working?
best regards
kisscool
Users browsing this forum: No registered users and 40 guests
