Motec PPL Sugestion on GPS
Information about using GPS units with motec devices
Postby Motec_Master on Thu Nov 13, 2008 8:18 pm
Please guys find a way for us to use the GPS sensor directly with the ECU .... We have to use it with the loggers :roll: ...
If it can be logged and viewed in the ECU it can be useful atleast ... U know like in auxillary tables etc... etc....
GPS is much easier than having to do a speed sensor setup... I know you guys can do it
Motec_Master
Re: Motec PPL Sugestion on GPS
Postby IDP on Fri Nov 14, 2008 12:11 am
The Motec 10HZ Gps has a digital speed output which can be used in any ECU
IDP
Postby Motec_Master on Sat Nov 15, 2008 3:19 am
Will order one now thnx
I thought it can only be used by the central and dash logger
Motec_Master
Postby JamieA on Sun Nov 16, 2008 8:26 pm
Be aware, only the MoTeC USA 10hz GPS has a dig output for an ECU, the plastic case models sold elsewhere dont have that available.
JamieA
Postby chelspeed on Wed Apr 01, 2009 11:43 pm
Is there a manual or datasheet for the US professional / motorsport GPS?
chelspeed
Postby OmarK on Mon Nov 26, 2012 3:18 pm
There is manual for the GPS BL-1 which is on the MoTeC USA website in the downloads section. GPS lat and long and other GPS data can now be logged in the M84 and 'hundred series' ECUs.
OmarK
Postby chelspeed on Thu Nov 29, 2012 4:22 am
Thanks for your reply. Not sure if you saw the dates but in the 3 years, 8 months since I asked the question I have found the datasheet, bought the GPS, set it up, modded it to display UK summer time and winter time, modded the comms to add extra channels for precision, number of sats etc etc, done numerous events and have now retired from competition!! But hopefully the reply will help someone else.
chelspeed
Return to GPS Information
