is there any base setup for the Delco 3-way boost valve to start with ?
It'll drive an external waste gate.
Thank you.
Martin wrote:http://www.motec.com.au/filedownload.php/v14.pdf?docid=1307
Martin wrote:If you want a base setup for PID boost control you first need to understand PID itself. If you want i can help you with documents on PID, just so that you know what it is that you are adjusting. PM me if you dont have it allready.
PID is very spesific to the installation, so a base setup would be different for different aplications.
