Delete AV Channel not used
Postby insomnia on Mon Nov 19, 2012 6:50 am
Hello guys,
Can i delete the channels not needed in the M84?
I have all the time Error Message from the AV3 (MAF) AV4 (FP) and AV6 (EGT).
In the Sensor Input the "Delete" button is grey, inactive....
Any advice?
Regards
Francois
insomnia
Re: Delete AV Channel not used
Postby Scott@FP on Tue Nov 20, 2012 6:24 am
Looks like about all you can do currently is to set up the sensor, then set the Diag Hi and Lo limits outside the range for the unconnected sensor, like Diag Lo of -0.5v and Hi of 5.5v, then it won't go into error.
Scott@FP
Postby insomnia on Wed Nov 21, 2012 9:55 am
Hi Scott,
I think this is a good direction!
Thank you for your reply.
Regards
Francois
insomnia
Return to M84 ECUs
