software release
software release
Postby morris981 on Thu Oct 09, 2008 5:05 pm
hi all
i write from italy and i need a motec m800 v3.32 release for mitsubishi evo6 plug and play.can you help me?i search a start file for cadillac cts-v ls2 engine.sorry for my orrible english
morris981
Re: software release
Postby Martin on Fri Oct 10, 2008 7:46 am
Id suggest you dont use 3.3 rather upgrade the ECU to 3.5
The startup file...is it for a GM Gen3 LS2 engine? Ive got plenty LS1 and LS2 maps but all modified engines. I would suggest you get a standard engine`s file from somebody
Postby morris981 on Mon Oct 13, 2008 8:00 pm
yes is it GM ls2 engine can you help me?do you have start file?
thanks
Morris
morris981
Postby Martin on Wed Oct 15, 2008 3:58 pm
Yes i do have LS2 Files, but they are not stanard engines. Fueling and timing will differ, but at leasts the ref.sync setup should suit you. Is this all you need?
Postby morris981 on Fri Oct 17, 2008 10:55 pm
yes!do you have?
morris981
Postby Martin on Sat Oct 18, 2008 2:05 am
PM me with your email address, ill pass it on to you
