Engine cannot start
Engine cannot start
Postby Peter on Fri Nov 09, 2012 11:09 am
Dear All,
We install MOTEC M800 to CAMPRO engine, the problem is engine cannot start i think we are wrong in our ref and synch. May I ask for help who has data for this engine so that we can start using MOTEC M800?
Peter
Re: Engine cannot start
Postby Dragon on Fri Nov 09, 2012 11:46 am
A ref/sync capture will help.
Dragon
Postby Peter on Fri Nov 09, 2012 7:12 pm
we capture already the ref/synch but still cannot start. our problem is the crankshaft is magnetic and the cam shaft is hall.
Peter
Postby Peter on Fri Nov 09, 2012 9:51 pm
We have a problem in cofiguration of CRIP our CRIP is 60-2 and attached is the ref/synch capture. Who can help us to start the engine using MOTEC M800 if connect the engine the stock ECU it is working and no problem.
r3 ref-sync capture.jpg (220.77 KiB) Viewed 20001 times
Peter
Postby stevieturbo on Sat Nov 10, 2012 9:48 pm
What are the trigger voltage thresholds for the ref signal ?
It is a good stable signal ok, but a very low voltage.
I'm no expert, but it almost looks like the centreline of the waveform doesnt actually go +/- over the zero line ? Unless you have offsets specified in the trigger settings, then it will never be recognised.
I'm sure someone more experienced will be able to advise better
http://www.youtube.com/watch?v=9e5JJHwaehw
stevieturbo
Postby Peter on Sat Nov 10, 2012 10:06 pm
What is the best solution for this? Anyone can help? please we have already one week for this problem.
Peter
Postby stevesingo on Sat Nov 10, 2012 11:05 pm
Can you post up your config file as an attachment?
Steve
stevesingo
Postby stevieturbo on Mon Nov 12, 2012 11:07 am
Peter wrote:What is the best solution for this? Anyone can help? please we have already one week for this problem.
Where in the world are you ? Is there a Motec dealer or mapper near you ?
stevieturbo
Postby Dragon on Mon Nov 12, 2012 11:49 am
A MoTec dealer should be able to sort out your problem in minutes.
Or, if you prefer, post up the config file.
It is more difficult to help remotely.
Dragon
Postby Peter on Mon Nov 12, 2012 5:01 pm
Dear All,
I'm sorry because this is our first time to use MOTEC, the engine is CAMPRO. attached is the configuration
R3 satria ECU config.e35
(72 KiB) Downloaded 1538 times
Peter
