by YuriK on Wed Nov 07, 2012 5:22 pm
The way to send GPS Time to the dash is to create custom data set with GPS Time HW and GPS Time LW in the ECU and export it. Then in the CDL3 comms select the custom set template and change so instead of two "Channel Not Found" it receives GPS Time (or GPS Time 2 ) channel. Make sure to put 4 (Bytes) in the Length field and make Bit Mask FFFFFFFF in the Change Comms Channel screen.
What will happen, after you've done that is that ECU sends two 16bits channels and CDL3 receives one 32 bit channel. So now you have GPS Time channel in your CDL3 and all you need to do is to setup the display to show the channel.
Regards!
