SDL and 4x EGT alert options
Postby bazeng on Thu Nov 01, 2012 9:17 pm
Hi All,
I will.be running a 4 channel EGT amp to the SDL.
It will be used on a 4 cylinder monitoring each exhaust runner.
What can I do on the SDL to monitor any possible issues that may occur with the leaning out of one cylinder?
My thoughts are:
1. Tune the car, log the EGTs
2. Use log to determine normal egt temps and setup alarms that will trigger if any temps go above the logged values using rpm / egt temp as axis.
Is this achievable?
Are there any other options?
bazeng
Re: SDL and 4x EGT alert options
Postby Holmz on Fri Nov 02, 2012 2:09 am
Are you looking for the whole engine to be out?
Or one cylinder to be different than the others?
Holmz
Postby bazeng on Fri Nov 02, 2012 4:01 am
Either.
Anything that will put the engine at risk.
Especially with this e85 injector blocking goo that i see online and on friends vehicles.
bazeng
Postby bazeng on Fri Nov 02, 2012 4:03 am
I will be linking the alarm to an output which will trigger the ecu to go into either boost cut or ignition / fuel cut.
bazeng
Postby Holmz on Sat Nov 03, 2012 11:17 am
bazeng wrote:Either.
Then you may want to compare the 4 EGTs and when one deviates higher then the rest, then that may give you insight into lower fuel flow on that injector.
Holmz
Postby bazeng on Sun Nov 04, 2012 12:36 am
Is that achievable in the software?
If the difference between all 4 signals is greater than a certain percentage, activate output x....
bazeng
Return to ADL, ADL2 and SDL
Users browsing this forum: Bing [Bot] and 2 guests
