Hi All,
I will.be running a 4 channel EGT amp to the SDL.
It will be used on a 4 cylinder monitoring each exhaust runner.
What can I do on the SDL to monitor any possible issues that may occur with the leaning out of one cylinder?
My thoughts are:
1. Tune the car, log the EGTs
2. Use log to determine normal egt temps and setup alarms that will trigger if any temps go above the logged values using rpm / egt temp as axis.
Is this achievable?
Are there any other options?
