Hi all,
I have an old Motec M8 which has wideband lambda, data logging and traction control activated. I am running the ECU on a 434 ci Dart Block Chevy V8 with a Kinsler injection system. The engine was mapped open loop without lambda enabled, but I now want to install into the completed exhaust system and run the engine in closed loop control.
From looking at forums and the M8 instruction manuals, is it correct that the unit is designed to run on wideband sensors only, or can normal narrowband sensors be fitted?
On another thread on this forum, it was stated that only a Bosch LM11 0258 104 002 sensor (now updated to LM11 0258 104 005 I believe?) would work on an M8. I think that this is a 4 wire wideband sensor, but some web sites do not state that it is wideband.
Can anyone please help me clarify what I should use with this ECU please as I'm not 100% convinced I have the correct sensor part number...
Many Thanks,
