M1 and M141
Hi, my M141 is not working after an engine move (i.e. worked in one car, but when the same engine swapped into another car, with the same loom, the car wont start).
In my quest to find out possible causes I downloaded the M1 software and connected it to the ECU. The software discovered the ECU, but when I tried to open it, I received this error message "Failure to retrieve ECU data".
I'm running the ethernet cable through a USB-C adapter to the laptop (not sure if this is relevant).
What could possibly be stopping the data being retrieved?
