Throttle connection in Genset diesel engine with M142 ECU
This sub forums is for discussions relating to the MoTeC M1 Diesel Packages
Postby Ankur on Mon Dec 07, 2020 1:07 am
Hello Sir,
We have M142 GPR diesel ECU and we want to operate Diesel Genset Engine using this ECU.
As it is mentioned that throttle position sensor is essential for this ECU, however, Genset engine don't have any throttle pedal sensor. Please guide us regarding this that how we can control load in genset engine using M142 via throttle pedal sensor.
Regards
Ankur Kalwar
Ankur
Re: Throttle connection in Genset diesel engine with M142 EC
Postby Stephen Dean on Mon Dec 07, 2020 9:21 am
Hi Ankur,
Without knowing the full specifications of the GenSet this should be possible, as long as there is some form of load input into the M1.
If you would like to send more detailed information to support @ motec.com.au we can go into further detail.
Return to M1 Diesel
