V2 Configuration on Additional Micro SD cards used..?
Forum for discussions on the MoTeC V2 Camera system
Postby proformance on Thu May 31, 2018 4:15 pm
Is it necessary to have the V2 configuration on each 32GB Micro SD card inserted into the V2 Camera.?
(Or, in other words.)
If once the V2 Camera is configured via a micro SD card, may a blank 32GB Micro SD card be inserted and have the V2 Camera operate and record properly.....? Post being powered "OFF" for several weeks.?
Also, I have had no success with the V2 recording in US values (IE: MPG and PSI.) I have these channels default to MPH and PSI in the Dash config, but I can only get KPH and KPA to record. Are there recommendation on how to remedy this?
Gary
proformance
Re: V2 Configuration on Additional Micro SD cards used..?
Postby adrian on Thu May 31, 2018 5:44 pm
The configuration only needs to be on the SD card for one power up. After that it is saved permanently to the device. You can use a blank SD card from then on, you only need the configuration files again if you want to change some settings.
Below is a CAN template that will transmit the channels to the v2 in Imperial units.
v2_Transmit_Imperial_0x01F_Version 1.CC7
(8.12 KiB) Downloaded 1487 times
Return to V2
