Terminating CAN Resistor in V2 Cable?
PostPosted: Tue Oct 03, 2017 9:11 am
by Herrubermensch
Planning a V2 installation, but will probably need to use more than 500mm of cable between CAN bus and V2 unit. This must be a pretty common situation, but I see no mention of the V2 connecting cable incorporating a 120 ohm terminating resistor on the CAN Hi and CAN Lo connections. Does it have such a resistor or will I have to cut the V2 cable at 500mm and insert one? I am at a disadvantage because I am designing my harness before actually acquiring the V2. Thanks.
--Peter
Re: Terminating CAN Resistor in V2 Cable?
PostPosted: Tue Oct 03, 2017 11:40 am
by adrian
The Power/CAN loom that comes with the V2 kit has a terminating resistor built in.
I see that the datasheet doesn't mention this, I will get it updated.
PostPosted: Tue Oct 03, 2017 1:28 pm
by Herrubermensch
adrian wrote:The Power/CAN loom that comes with the V2 kit has a terminating resistor built in.
I thought for sure that was the case, but am very glad to have confirmed it. Thank you!
--Peter
