v2 Start/Stop conditions - expanded functionality
Forum for discussions on the MoTeC V2 Camera system
Postby hnatho on Thu Apr 20, 2017 3:19 am
I am configuring a new install of a v2 system. This particular installation would benefit from a more complex Start/Stop logic that is currently available through the v2 manager.
This installation shares a CAN-bus with a CDL3, and I can see in the *.v2 config file how I might add my trigger conditions to the CAN Tx message.
My question is: Does anyone know if I can simply move the relevant 'condition' code lines from "speed" or "rpm" to another channel? If I do this, I can no longer open the files in the v2 manager, but haven't tested the theory on the camera system.
Failing that: Can I change the boolean operators from the default "or" on the start channels or the default "and" on the stop channels?
Thanks!
hnatho
Return to V2
