v2 Video live feed
Forum for discussions on the MoTeC V2 Camera system
v2 Video live feed
Postby jracerx on Fri Mar 31, 2017 2:46 am
hello all,
I have the v2 and use it with a c125. is there a way to view the video live as you are installing it in the car? i looked in monitor channels, devices, connections, and . I couldn't find anything to view the live stream with . I know the v2 records to the sd card, but was hoping if I set the v2 to key on recording there would be a way. as of right now I am having to do short videos and then watch it to see if it needs adjusted.
any help is greatly appreciated.
jracerx
Re: v2 Video live feed
Postby adrian on Fri Mar 31, 2017 8:10 am
Yes you can live view the v2 camera in v2 Manager. Simply connect a mini USB cable to the underneath of the camera (you may have to remove the thumb screw to get access) and then connect it to your laptop.
Make sure you remove the SD card from the camera and then power it up. In v2 Manager go to View>Auto Connect Camera.
Postby jracerx on Fri Mar 31, 2017 9:33 am
thank you that worked.
jracerx
Return to V2
Users browsing this forum: No registered users and 26 guests
