V2 Video section?
Sun Jan 29, 2017 12:09 pm
by locash
Having some issues getting a V2 video camera set up, and also curious if there is going to be any more configurability in the software eventually? Can't edit the display templates or change/add displayed sensors currently?
Re: V2 Video section?
Mon Jan 30, 2017 8:47 am
by adrian
What issues are you having with the setup?
There is a plan to add features to v2 Manager to allow editing of the onscreen gauges however this work isn't in the current development schedule so I do not know when it will be completed.
Wed Feb 01, 2017 10:32 am
by locash
Trying to get the V2 to receive data from the M800 is my current issue. The instructions are somewhat vague on doing this.
Thanks!
Wed Feb 01, 2017 9:49 pm
by adrian
You will need to send a Custom Data Set as a compound message out of the ECU. Below is an image of how to configure the custom data set.
- M800 to v2 CAN Setup.png (8.62 KiB) Viewed 38365 times
Even if you don't have some of those channels you have to put something in as a place holder, so for instance if you don't have lap number, you have to put some channel in otherwise the two G-Force channels and lap distance won't work.
Wed Feb 01, 2017 10:04 pm
by adrian
Something I forgot to mention is that the address needs to be set to 31.
Sat Feb 04, 2017 9:50 am
by locash
Thanks, which CAN data choice would I select? Obviously the V2 did not exist back when the software was created.
Sat Feb 04, 2017 3:27 pm
by David Ferguson
You select the value 7 (Custom Data Set 1 Compound) for CAN 0 Data.
If you used Custom Data Set2, then you have to set the value to 10 (Custom Set 2 Compound Tx) for CAN 1 Data.
Sun Feb 05, 2017 6:00 am
by locash
Unfortunately, I am using an SDL dash logger on Can0 data, so I guess I will have to use Can1 data and use custom set 2. Too many different CAN devices on this car I guess. I will give that a shot, and if that doesnt work out, I will try to connect it via my SDL dash I suppose..
Thanks!
Sun Feb 05, 2017 6:16 am
by David Ferguson
It would be much easier to setup the SDL to talk to the V2 Video. There is a template you can just load.
Sun Feb 05, 2017 10:13 am
by locash
I ended up connecting it to Can1 on the SDL3, although there was no v2 video template, I ended up using the VCS TransmitCompound full template and just setting constants for the channels I am not using..
Thanks for the help!
