Sticky / freeze values
PostPosted: Tue Jun 18, 2024 9:43 pm
by karel021
Hi is there a way to get values to stick for x amount of seconds.
For example I would like to get the brake bias values to stick. After a braking into a corner and then stick as the peak values to be displayed for x seconds
Re: Sticky / freeze values
PostPosted: Thu Jun 27, 2024 1:40 am
by Anthony
Have you tried the freeze display on condition function?
I haven't actually tried it in real life but in the simulator it looks like it might do what you want.
Goto pages > Select your brake bias channel > Freeze display on condition > add condition.
You can try with these settings.
Brake Pressure = Greater than (A value for you to decide)
Set -
"Result is false when" to "remains false for greater than or equal to" and set the time to the amount of seconds you want it to freeze for when the brake pressure drops below the level you set above.
PostPosted: Tue May 06, 2025 11:20 pm
by karel021
Hey sorry for the late reply, i will have a crack at this and get back if it worked or not :)
