C1812 Set animations while navigating a menù
Thu May 23, 2024 1:58 am
by albertocaresio
In the Motec C1812 I am setting rigth now there are 5 different driving modes. My goal would be to set an animation every time you navigate, for example, from 1 to 2 and the reverse one when you go back, keeping the last frame at the end of it on screen.
Do you know how I can proceed? I'm a beginner user, not very skilled, sorry.
Thanks in advance
Alberto
Re: C1812 Set animations while navigating a menù
Fri May 24, 2024 11:00 am
by Stephen Dean
You need to post your Display and DC configurations so that people can assist you.
Fri May 24, 2024 7:11 pm
by albertocaresio
Hello, I'm working on a C1812 and I created a .dbc file from D1xx settings on Dash manager. I apologize, I'm not sure if this is what you asked, would you be so kind in case I'm wrong to tell me where can i find the info you asked for?
Thank you.
Mon May 27, 2024 10:02 am
by Stephen Dean
You need to use the Internal Display (Using Display Creator) option for the Display Setup. Using the Internal Display (D1xx) option configures the file for using with a D series external display, which is different.
In Dash Manager, you can go to File | Save As... and single click select the configuration file that you are working on, then click the Export button to export the file to a location such as your desktop, then upload the file to here.
With Display Creator, You can go File | Open and right click on the Project file, this brings up the Show in Windows Explorer option, select this and then copy the file from that location.
Mon May 27, 2024 7:42 pm
by albertocaresio
Hello Stephen, thanks, I'm already using the Internatonal Display D1xx.
Wed May 29, 2024 12:12 pm
by Anthony
If you share the current display creator configuration here we can help.
