First time Using Display Creator
I am attempting to move from the Internal display to using Display Creator.
When choosing the display creator I get an empty screen. Is there a way to export the internal configuration so the display creator gets all the channels and addresses?
I also when run channel checks I get an error that states "Video Source" is not there but when try to add it the Edit Channels tool states it is already there. How can I publish a channel that is in the database but does not show up in the list?
UPDATE: The channels show up when you check "Show unassigned Channels"
Still need to make the DBC file from configuration while not connected to a device
Thanks in advance for any advice
