Switch group values problem
PostPosted: Mon Aug 14, 2023 11:10 pm
by BFGracing
Hello
I have a problem. When Im setting up my switch group conditions it only takes full digits with no decimal places.
When it is set for big numbers like EGT it is easy like more than 860*C
But when it goes into lambda values I need switch to operate in decimal places like:
"Lambda less than 0.88"
But display creator automaticly set it into:
"Lambda less than 1.00"
What Im missing? I can not set switch group conditions in decimal values.
Re: Switch group values problem
PostPosted: Tue Aug 15, 2023 10:53 am
by SOReilly
Are you using the latest version of Display Creator?
I have tested this and wasn't able to recreate the issue you are having.
I tested decimal values both less than 1 and greater than 1.
