DC and a G-circle gauge (X-Y/scatter plot)
Hi All,
I have a 2020 Mustang GT with a g circle gauge in the cluster (see pic) essentially its a graphic of concentric circles, with an X-Y plot of lat (x axis) and long (y axis) with the "needle" or cursor as a dot that moves in the x-y plane across the static graphic.
I have a 2018 Focus RS which i have decoded the x & Y g sensors on CAN, among some other powertrain stuff....i wish to do the g-circle thing for my C187 for the RS with X_Y (or scatter plt) graph over a fixed image grpahic.
Another page i wished to create was a compressor map page...i have instrumented pre/post comp and turbine temp & pressure, and turbospeed, and wish to plot the current corrected massflow and Pressure ratio as a X-Y plot again over an mage of the compressor map (which i have, PR is y axis, Corr Maassflow x axis). I am doin all the maths calcs for the corrections, the channels i am reading now are accurate, just want a fancy way to plot them.
I already have started the rear axle torque splits (GKN rear torque vectoring), and have a functioning engine power meter (as i found the flywheel output torque EngOut_Tq_ CAN signal an RPM on CAn, and multiply them to get a Engine Power)...just like a Veyron. Very interesting analysing what is coming out....the next one is using the onboard yaw and steeering torque and angl from the steering CAN
CAn anyone assist with the best way to do an X-Y/Scatter plot in DC...i have seem the new x-y #D object, but NO INFO (except the forum thread below, which was quite vague)
