Display creator fastest lap
Postby Jeremy on Wed Oct 27, 2021 1:42 pm
If my M1 does the lap timing and data is sent to my c125 using display creator, is there a way for display creator to calculate the fastest lap?
I am using GPS beacons in the M1.
Thank you
Jeremy
Re: Display creator fastest lap
Postby David Ferguson on Wed Oct 27, 2021 3:15 pm
It's best to do Lap Timing calculations in your C125. You do this with C125 Dash Manager, not Display Creator. Look under Calculations->Lap Time and Number.
Postby Stephen Dean on Thu Oct 28, 2021 8:44 am
The preference is to have the GPS into the Dash and then CAN into the M1, rather than the other way around. I have replied to your other post with the changes needed to the Dash configuration to get the GPS over CAN working.
Display Creator only controls the Display portion of the Dash, the Lap Timing and other Functions are done in the dash hardware.
Return to Display Creator
