Tire temperature visual representation
My driver wants to see tire temperatures (internal carcass from TTPMS IR) on his dash (secondary display) represented in graphical way i.e. a square shape for each tire that would change it's color according to signal (tire temp). So that he knows when the tires are up to temperature and when it is time to start preserving them. For example in I2 I would use a color graph with a color band and it will change color from blue to green, to yellow, to red according to channel value.
Why don't we have this functionality in DC - for example we could use a rectangle/static bar and assign a channel + color band so that it would change color according to channel value. As is I had to use multiple bars on top of each other with different colors, with conditions assigned and it is really cumbersome.
Also it will be very convenient to have more conditions - not just "greater than" or "less than". At list "greater than" "and" "less than" used together would make life easier if you know what I mean. May be it is there and I simply don't know how to use it?
Also, why don't we have conditions for channel values? For example I would want some channel value text to change color according to value. If there was a condition I could have say 3 channel value texts with different colors in a group and each would show/hide according to assigned condition.
As I said - may be it is possible with current DC and I don't know how to do it? If that's the case than I would really appreciate some advise
Thank you,
Ted
Thank you,
Ted
