Error Calculating Device Configuration (Contact MoTec)
Postby Kroozer on Sun May 30, 2021 11:06 am
This error started to occur when I wanted to cut and paste a new page from a different project into an existing project.
I have done this before in an older version of Display Creator and had no issues. :P
Current version (x64) 6.4.0.95
I have looked and followed the thread for (WINDOWS 10 x64 COMPILER ERROR) and this may be a different issue as I could not resolve my issue (Error Calculating Device Configuration).
I have logged a case #30755
Any suggestions are welcome.
This page is what I want to re insert into a project
Error message that comes up
Temp Folder has files in it
Kroozer
Re: Error Calculating Device Configuration (Contact MoTec)
Postby Kroozer on Mon May 31, 2021 2:30 pm
Awesome, Motec got back to me..
It looks like DC isn't copying across all of the settings inside the bar graphs
(the needle start and end points are either 0 or a weird number) and that is
causing the issue. I have logged a bug report in our system to get it fixed, in
the mean time I have manually fixed up your config so it will build properly
now.
Many Thanks
Ticks not copied across properly
DC Bug.png (312.85 KiB) Viewed 4701 times
Kroozer
Return to Display Creator
