Growing numbers on RPM/Speed meter
PostPosted: Fri Apr 30, 2021 1:07 am
by BFGracing
Hello friends!
Im working on my C1212 and... have idea to set RPM/Speed gauge to grow up actual number paralel to the needle.
Do you have any ideas how to set it? Same is set by BMW on C125... but how they do this?
Regards Piotr :)
Re: Growing numbers on RPM/Speed meter
PostPosted: Fri Apr 30, 2021 2:29 am
You would use a Switch object to select between multiple groups each with a different text object.
PostPosted: Thu Jun 10, 2021 6:59 am
by TudorMiron
Many thanks David!
This is an answer to my post (awaiting approval) about being able to change channel value text color.
Thank you,
Ted
