D153 remember value
D153 remember value
Postby thr on Sun Aug 25, 2019 7:17 am
Hi.
We got a D153 as second display for our co-driver.
(The primary is a C127)
I’v created a menu in DC on the D153, where the co-driver is able to set a value on a channel (unassigned).
The value is compared to another channel to activate an alert.
My problem is, that the channel reset’s, when the D153 turns off/on.
Can I solve that ?
Thanks !
thr
Re: D153 remember value
Postby adrian on Mon Aug 26, 2019 2:27 pm
The D153 does not have the ability to save channel values through a power cycle. What you would need to do is send the menu channel on CAN to the C127, preserve it there and then send it back.
Postby thr on Thu Aug 29, 2019 3:58 am
Thanks Adrian
I thought so, about the D153
But as I can see, the D153 can’t transmit, only recieve.
Or am i wrong ?
Br Brian
thr
Postby adrian on Thu Aug 29, 2019 9:05 am
As long as you have the latest version of DC then it can transmit too.
Just create a new message in the communications setup and then on the right hand side you can select transmit instead of receive.
Return to Display Creator
