Vertical Dash
Vertical Dash
Postby mhdazhar on Thu Aug 09, 2018 2:30 am
Is it Possible to Rotate the text,channel values and all the page elements available in the display creator,due to space limitation i need to position my dash screen vertical in place of horizontal position.
mhdazhar
Re: Vertical Dash
Postby Stephen Dean on Thu Aug 09, 2018 12:07 pm
The possibility of doing this is currently under investigation, especially for the 12" screens.
Re: Vertical Dash
Postby icanfly on Sat Aug 21, 2021 6:58 am
I'm assuming per my other thread about rotating text that this has not come online and does not have a current fix version?
icanfly
Re: Vertical Dash
Postby adrian on Mon Aug 23, 2021 10:39 am
Nope, this is possible, you select the Display Orientation when you first create a DC project (and you can change it in the settings afterwards).
You just can't have a mix of vertical and horizontal text at the moment.
Re: Vertical Dash
Postby icanfly on Tue Aug 24, 2021 11:38 am
Thanks for the clarity @adrian.
icanfly
Return to Display Creator
