C1212 Displaying CAN data without DM configuration?
Postby Robin Poenisch on Wed Aug 08, 2018 6:18 pm
Hello everybody,
is it possible to use the C1212 with Display Creator enabled to only show channels received via CAN from various devices? i.e. using C1212 as stupid display only, with no need to have a Dash Manager configuration?
I know the possibility of setting up CAN templates in Dash Manager and then display the received channels with Display Creator, but I would like to go the "direct" way. Is this possible? If so, which CAN has to be used? CAN1 or CAN2?
thanks,
Robin
Robin Poenisch Motorsport
Engineering Services
Electronic Systems
http://www.facebook.com/Poenisch.Motorsport
http://www.poenisch-motorsport.de
Robin Poenisch
Re: C1212 Displaying CAN data without DM configuration?
Postby Stephen Dean on Thu Aug 09, 2018 12:02 pm
Hi Robin,
Due to the way that the displays work, you need the DM config to be created as this is used to send the data to the display.
Return to Display Creator
