sms modul and display creator
Postby mecajet on Tue Mar 07, 2017 2:09 am
hi,
i try to configure sms modul in display creator but it's not work.
the sms modul work on internal layout but no on internal display creator;
an idea ?
mecajet
Re: sms modul and display creator
Postby adrian on Tue Mar 07, 2017 2:32 pm
How have you got it setup?
If you simply change the Display Setup from Internal Fixed Layout to Internal Display Creator, add the channels you want displayed and leave everything else the same in your Dash Manager config then it should just work.
Does the rest of your DC config work?
Postby mecajet on Tue Mar 07, 2017 10:24 pm
my DC work as well.
but only the sms modul don't work with an DC setup.
i try with a fixed layout just for test an it work.
the sms modul have a dark setup lol, only rs232 setup but no channel no configuration possible.
mecajet
Postby adrian on Wed Mar 08, 2017 8:42 am
I have tested it here, if it works with the fixed layout and as long as you leave the alarms setup in your Dash Manager config then it just works with DC.
Are you able to send me your Display Creator and Dash Manager configs that you are having an issue with? You can send them to support@motec.com.au or post them here, which ever you prefer.
Postby mecajet on Wed Mar 15, 2017 6:45 am
Thank you, your post help me.
I worked on DC before buying the dashboard and deleted all the basic alarms in DC new project because I wanted to create a mask for all my alarms.
I have copy my pages in a new project and it works.
mecajet
Return to Display Creator
