DC 1 file to DC 6 import problem
Postby mecajet on Fri Mar 03, 2017 9:46 am
hi,
i have create a file with DC version 1 but now with my C127 i have the DC 6, and whend i open my project (or import)
all size and the position object a false.
my project is finish and i have many object i can't relocate et re-size all one per one.
a idea ?
mecajet
Re: DC 1 file to DC 6 import problem
Postby adrian on Fri Mar 03, 2017 11:10 am
This is most likely because of the region you have set in Windows. If you have a region that uses commas (',') for the decimal place instead of dots ('.') then it will cause this issue.
We are aware of the problem and it will be fixed in the next release, however until then if you want to use v6 of DC you will need to change the Windows region to one that uses dots for the decimal place.
Postby mecajet on Fri Mar 03, 2017 6:59 pm
thank you
it's good :)
mecajet
Return to Display Creator
