SDean wrote:The DBC file used in Display creator has to match the config in the dash that is generated by the Dash Manager, if they do not match, you will get the CAN Comms Timeout error message. Display creator is not directly communicating with the CAN bus, it still uses the Dash hardware and CAN templates to decipher the data coming in on the bus, and the dbc is used as a roadmap for this data.
