Filtering Values
Filtering Values
Postby Robin Poenisch on Wed Dec 09, 2015 9:46 pm
playing around a bit with a C185 and Display Creator. Wondering how to filter numeric values for showing on the dash. If I use Dash Manager, I can input a filter value for each channel. How can this be done in Display Creator? Except for building math channels in Dash Manager and sending filtered values to Display Creator.
thanks,
Robin
Robin Poenisch Motorsport
Engineering Services
Electronic Systems
http://www.facebook.com/Poenisch.Motorsport
http://www.poenisch-motorsport.de
Robin Poenisch
Re: Filtering Values
Postby adrian on Fri Dec 11, 2015 11:01 am
Hi Robin,
It depends on exactly what you are trying to do. DC doesn't have a way of 'filtering' a channel however if all you want to do is make a numeric channel more 'viewable' you can get a similar result by reducing the refresh rate (select the channel value and it is one of the properties in the right hand window).
Adrian
Postby Robin Poenisch on Fri Dec 11, 2015 7:01 pm
Hi Adrian,
thanks for your answer. Yes, I know about the "Refresh Rate". But with this you still have "jumping" values, with large differences between each displayed value which still is not very good to read in some cases.
The filter-function where you can enter a time constant and get a mean-value is much better. Would be very good to have this also in DC.
regards,
Robin
Electronic Systems
Robin Poenisch
Postby adrian on Mon Dec 14, 2015 10:45 am
Hi Robin,
I have added channel filtering as a feature request for DC.
Adrian
Postby the_bluester on Mon Dec 14, 2015 9:39 pm
What I have thought would be ideal would be the ability to set up all of your channels and other functions in a "Vanilla" form in the dash manager and use the DC software purely to lay out the visual display of the result.
the_bluester
Postby Robin Poenisch on Tue Dec 22, 2015 11:24 pm
Thank you Adrian!
That is one of the biggest advantages of MoTeC
Electronic Systems
Robin Poenisch
Postby FoxSTI on Sun Aug 28, 2016 10:02 am
has this already been implemented ?
FoxSTI
Postby adrian on Mon Aug 29, 2016 11:00 am
This hasn't been implemented yet, it is scheduled for release after next. It should be released by the end of the year.
Return to Display Creator
