Gear Display "N"
Re: Gear Display "N"
Postby FoxSTI on Wed Oct 26, 2016 2:08 pm
I'll look into to that. I haven't changedone it.
Where do I look?
FoxSTI
Postby georgemcf on Wed Oct 26, 2016 2:13 pm
David,
If you were answering my question, I have been trying to do this just in Dash Manager, not in Display creator. I was trying to figure out if I could display R instead of 7 without having to pay for the creator licence, as this is my only current issue with the standard templates.
George
georgemcf
Postby Stephen Dean on Wed Oct 26, 2016 2:22 pm
Under Calculations | Gear Detection
Gear Detection.PNG (18.79 KiB) Viewed 16140 times
Postby adrian on Wed Oct 26, 2016 2:38 pm
George,
Below is a table of the input values and the displayed values for the gear channel in a standard display setup (ie not using display creator).
You will need to use a 2D table to convert the values you are receiving on CAN to the values needed by the dash to display what you want.
Gear Display.png (4.87 KiB) Viewed 16139 times
Return to Display Creator
