Sticky / freeze values
Postby karel021 on Tue Jun 18, 2024 9:43 pm
Hi is there a way to get values to stick for x amount of seconds.
For example I would like to get the brake bias values to stick. After a braking into a corner and then stick as the peak values to be displayed for x seconds
karel021
Re: Sticky / freeze values
Postby Anthony on Thu Jun 27, 2024 1:40 am
Have you tried the freeze display on condition function?
I haven't actually tried it in real life but in the simulator it looks like it might do what you want.
Goto pages > Select your brake bias channel > Freeze display on condition > add condition.
You can try with these settings.
Brake Pressure = Greater than (A value for you to decide)
Set -
"Result is false when" to "remains false for greater than or equal to" and set the time to the amount of seconds you want it to freeze for when the brake pressure drops below the level you set above.
Anthony
Return to Display Creator
