set engine rpm channel
Postby CarloL on Sat May 21, 2016 11:44 pm
Hi
Assumption: the software will act as an Emulator and I do not need any Motec display hardware?
I am playing around with the software , and trying to mimic what was done in the webinar
https://www.youtube.com/watch?v=efQObamSChw&wide
    I have stumbled on how to setup the Engine RPM Channel ? It is taken for granted in the Webinar I know how to
    I am trying to create a Splash page with a Logo prior to the main page load but it said I need to set a condition on the 2nd page (no trigger condtion) , 2nd page has the Tacho
any help appreciated :D
CarloL
Re: set engine rpm channel
Postby David Ferguson on Mon May 23, 2016 5:13 am
Here is the Lotus Sport Display Creator project that goes with the DBC file I posted in your other thread. It has a splash screen, and multiple pages so you can see the conditions that are used for each page.
Lotus Sport C125 DCProj.zip
(350.01 KiB) Downloaded 1676 times
Postby CarloL on Mon May 23, 2016 7:32 am
Thanks David :D
CarloL
Postby CarloL on Mon Apr 15, 2019 9:08 am
Hey David
Mssing with the Display creator again , splash screen stopped working , same in your Lotus project , cannot figure out why
any idea?
CarloL
Postby David Ferguson on Mon Apr 15, 2019 11:53 am
Display Creator has undergone significant changes since I created and posted that project. I would probably just create a new project from scratch.
I suggest you start with the most recent version of Display Creator, create a new project, work though as much as you can, then post your project and questions and we can try to help.
Postby CarloL on Mon Apr 15, 2019 7:28 pm
thanks David
I have not touched it in a while
CarloL
Return to Display Creator
