How display channel as On or Off instead of numbers
Postby NicD on Sat Jun 07, 2025 5:18 am
This is probably a stupid question but I can't seem to get a channel like a driver switch or Traction Control to display On or Off, it only displays the numerical value. Changing units on the channel doesn't seem to display any different, should I use a 2D table to create another output channel or what's the best way to go about this?
NicD
Re: How display channel as On or Off instead of numbers
Postby David Ferguson on Sat Jun 07, 2025 10:09 am
I think the standard dash manager will only show numeric channel values, but you can do what you want with Display Creator.
Postby NicD on Tue Jun 10, 2025 5:55 am
David Ferguson wrote:I think the standard dash manager will only show numeric channel values, but you can do what you want with Display Creator.
Wow, that's really disappointing I would have to purchase Display Creator to do something as simple as making it show On or Off instead of a 0 or a 1.
NicD
Postby David Ferguson on Tue Jun 10, 2025 7:21 am
Well, you could make an alarm condition when the value changes, and use the message "xxx Off" and "xxx On", make it auto-dismiss after 1 or 2 seconds.
