Use C125 as Engine Fan controll
Hi.
I have a c125 logger that i would like to use as a fan controller.
My setup is Motec C125 with I/O upgrade, Pdm15 and a 8 button keypad. (Engine ecu is still standard.)
I have no comunikation between the engine ecu and the logger because no Can is available.
Than a couple of sensors are connected to An volt inputs and calibrated, like engine temp, oil temp and pressure.
As far as i know it should be possible to send temp signal via can to PDM, but i cant figure out how..
My other option is to use a Aux output to trigger a SW input on the PDM, that i thought should be easier. But still i could not figure out how :-p
Anyone here that could guide me a bit? programming or working on computer is not what i usually do, but hope to make this work before next race.
( have a button on my keypad to start the fan for now, but during a race i have plenty of other things to think about :-p )
Stian_M
Stian_M
