C125 cant display 1 channel
Wed Mar 27, 2024 5:56 pm
by terryo
I cant seem to get gearbox temp to display on my C125 dash which is connected to a M1
if you look at the pics, the actual display of gearbox temp is allocated to the bottom line. Diff temp is there. G'box temp is missing.
lap time is also missing but im assuming thats cause the car is stationery'. Im quite sure it worked when i track tested the car recently
can anyone offer any guidance on this please?
Re: C125 cant display 1 channel
Wed Mar 27, 2024 8:30 pm
by NathanB
Hi Terry,
At present you have each value (diff temp, lap time and transmission temp) each on separate lines, not three values across a single line.
If you wish for all three values to show up at the same time next to each other, you will need to double click on the diff temp (or the first line in the bottom section of the display configuration) and tick on the 'value 2' and 'value 3' boxes, and place the desired channels in each of these. This will allow three channels to be shown on the bottom row.
At present the value displayed in the left slot in the bottom row will change when the 'display next line' channel becomes true.
This channel is normally tied to a user condition or directly to a button to scroll through these lines. If this is the method you want to use, save your current config and select file > new > m1 ecu and review the config. In this config the 'next button' is assigned to an available wired input, and the second user condition uses this button to trigger the 'display next line' channel, which will make the display change through the row of displayed values on the bottom row once for each button press (ie. Change to the next line)
Sun Mar 31, 2024 9:49 pm
by terryo
many thanks, i now see what ive done wrong and its all fixed
next query,,, ive selected option 1 for "race". I want the 270 degree "gauge" to display boost pressure. I cant seem to work out how to change the number of "ticks"...is it always 7??
the "tick point table "has columns labelled number and Kpa. what is "number"??
Mon Apr 01, 2024 4:32 am
by David Ferguson
Number is the text displayed next to the tick mark (you can leave them blank) so you could show just 1.2 for 1.2 bar at 120kpa. Kpa is the value to be used at that tick mark. Note you can easily do non-linear scaling by having a smaller or larger difference between tick marks.
Wed Apr 03, 2024 8:19 pm
by terryo
ok, ive tried that. i want to have a 50 ->350kpa gauge. for line 7, it tells me i cant have a value above 253kPA. where would this number come from??
Thu Apr 04, 2024 11:14 am
by Stephen Dean
Can you post the Dash config?
Thu Apr 04, 2024 11:53 am
by David Ferguson
I don’t think he is using display creator based on his original question.
Thu Apr 04, 2024 12:26 pm
by Stephen Dean
Your correct David, serves me right for working on a couple of related issues at the same time.
