I read the Anti-Alias help documentation of the dash manager and some stuff is still unclear to me.
1. Let say I logging a damper position sensor at 1kHz, should I use a Anti-Alias Filter?
Should I understand that the AI of the C185/187 is processing the signal at a high rate that 1kHz?
2. Does removing the Anti-Alias Filter reduce the CPU load? If yes, how much, any estimation in % of the logging rate?
What would be the best practice, logging at double the sampling rate needed for a channel or using the Anti-Alias Filter?
3. If some information are being broadcast on a CAN BUS at 1kHz and I am logging this channel at 1kHz, is there any use for the Anti-Alias Filter?
Thanks, François
