Same Track, Different Layouts
Postby benntrevv on Wed Nov 08, 2023 11:46 am
So Queensland Raceway has got 4 layouts and all i can see on the track list is "Queensland Raceway" with a track length of 3.12000km which is the national track
For the other 3 track layouts, is it as simple as adding 3 new tracks, all with the same co-ordinates as the original Queensland Raceway track, but changing the name of each track and also changing the length of each track or is it alot more complex than this?
I'm using a C125 with the GPS for track position, no beacon etc..
Cheers
Ben
benntrevv
Re: Same Track, Different Layouts
Postby Stephen Dean on Wed Nov 08, 2023 12:00 pm
Hi Ben,
You can only use one set of Co-Ordinates for each track, too do this you will need to leave the single Queensland Raceway location, and then change the track length to suit the layout that you are using.
Users browsing this forum: Bing [Bot] and 2 guests
