C1812 Vertical and longitudal acceleration not working
Postby DynoDom on Sat Oct 07, 2023 2:35 am
Hi
Vertical and longitudal accel GForce show a constant, identical, unrealistic number and those numbers do not change when the dash is moved. Both can not be zeroed.
Lateral G accel is correct.
All three values used to work just fine last week
Did I mess up something in the config? I would not know what though.
Please advise.
TIA
D
DynoDom
Re: C1812 Vertical and longitudal acceleration not working
Postby Anthony on Sun Oct 08, 2023 2:16 am
When you are connected to the dash with your laptop in dash manager you can goto online then monitor channels and you can view the current value of the channel to check it.
Anthony
Postby DynoDom on Sun Oct 08, 2023 6:15 am
Hi Antony
That is exactly what I did. My post is based on the online monitor channels readings.
DynoDom
Postby quadcam on Sun Oct 08, 2023 5:50 pm
If you go into Connections - Devices - Internal Pins you should be able to see the Scaling and Offsets for each of the 3 G channels. Maybe they have been inadvertantly altered from the correct values.
quadcam
Postby DynoDom on Sun Oct 08, 2023 10:50 pm
Hi quadcam
Good point. I will check and report Here.
Thank you
DynoDom
