C125 brightwater TPMS
Hallo,
standart motec dash config things are no problem for me.
But everything with CAN is a bit to much for me.
I bought a brightwater TPMS system and trying to implement this to my obd connected C125 in my tracktool.
https://www.brightwater.co.uk/datasheet ... _guide.pdf
Thinking just connect it with CAN and using under communication setup-> select-> brightwater TPMS config(which is already available in dash manager 6.4).
Sadly I can only see pressure values which are 1 bar higher in the dash than in real with a tirepressuregauge. Values in dash are also changing when changing the pressures in tires. So connections seems to work fine.
Temperatures and sensor voltage values are always 0!
Any ideas what changes has to be done?
