Shift light bar C1812
Mon Sep 25, 2023 10:31 pm
by DynoDom
Hi
Is it possible to add a row of shift light fields to the C1812?
If yes, how?
TIA
Re: Shift light bar C1812
Tue Sep 26, 2023 2:36 am
by greenamex2
I have exactly the same question after playing with Display Creator at the weekend!
Tue Sep 26, 2023 5:30 am
by DynoDom
@Greenamex2
..glad to see I am not alone
Tue Sep 26, 2023 9:46 am
by NathanB
You can add images and switch groups in based on conditions without issue. This would be triggered on conditions the same as a shift light. You can also add a pulse as part of the condition to add a flash function.
The only factor to consider is that it is not possible to make these 'lights' brighter than the background image, so you will rely on the contrast of the surrounding background to indicate it.
In practice I have found it ineffective, choosing to use semi transparent overlays for the same function in instances where an external shift light isn't implemented.
Thu Sep 28, 2023 6:01 pm
by DynoDom
Thanks to all for the information.
