Shift light bar C1812
Postby DynoDom on Mon Sep 25, 2023 10:31 pm
Hi
Is it possible to add a row of shift light fields to the C1812?
If yes, how?
TIA
DynoDom
Re: Shift light bar C1812
Postby greenamex2 on Tue Sep 26, 2023 2:36 am
I have exactly the same question after playing with Display Creator at the weekend!
greenamex2
Postby DynoDom on Tue Sep 26, 2023 5:30 am
@Greenamex2
..glad to see I am not alone
DynoDom
Postby NathanB on Tue Sep 26, 2023 9:46 am
You can add images and switch groups in based on conditions without issue. This would be triggered on conditions the same as a shift light. You can also add a pulse as part of the condition to add a flash function.
The only factor to consider is that it is not possible to make these 'lights' brighter than the background image, so you will rely on the contrast of the surrounding background to indicate it.
In practice I have found it ineffective, choosing to use semi transparent overlays for the same function in instances where an external shift light isn't implemented.
Postby DynoDom on Thu Sep 28, 2023 6:01 pm
Thanks to all for the information.
DynoDom
