Attempting to add TPMS to C125
Postby Leon74 on Wed Aug 30, 2023 12:58 pm
I’m new to the forum.
Great community here!
Our team has been working with a C125 dash for superbike racing for the last few seasons. The dash is part of a factory BMW S1000RR kit that comes with preconfigured C125dash, ECU, complete harness and many sensors (such as suspension potentiometers, brake pressure, etc) . The dash file is prepared and loaded prior to the factory shipping the kit to the teams and is set up to acquire almost all the data we could even need. It is an amazing system and has been a great tool.
Many of the channels are locked, but we do have the ability to add new channels. The CAN dash channels are running at 500kbps
We are trying to add a simple TPMS system (default set at 500kbps), one that we already have on hand, to the CAN 2 network.
Unfortunately, I don’t have much experience with CAN or creating the required DBC setup and it’s a little over my head.
I checked with the wiring harness manufacturer and the CAN 2 wiring already has a 100 ohm resistor built in where the run of wires terminate (so at least we know that isn’t the problem).
So far, I have tried adapting the template that I found here viewtopic.php?f=70&t=5307 by loading it into the dash and changing the CAN ID to 0x77e (as specified in the TPMS manufacturer protocol document). I was hoping that by chance that system may have been made by the same manufacturer as the one used in the previous post which had the template, and we might get lucky.
It was a longshot, but did not work. I can see the channels but the pressure reads zero when we look at it in the channel monitoring.
Is it silly to assume that the channel templates would be similar enough when setting up TPMS from different manufacturers that they would be interchangeable?
I can supply the TPMS protocol sheet and the dash file to anyone who is curious or post it in here if permission is granted.
Thanks for reading and thanks in advance from to anyone who can help this CANbus newbie.
Best regards,
Michael
Leon74
Re: Attempting to add TPMS to C125
Postby Stephen Dean on Wed Aug 30, 2023 3:10 pm
Hi Michael,
Different manufacturers will have completely different CAN addressing and message structures for their systems. I have even seen ones that are just rebadged versions from another company having a different setup to suit the existing CAB Bus networks of the company that is selling them.
I would recommend contacting MoTeC Europe's support team about this, as they are involved in the development of that kit, and will be able to make sure that there are no conflicts in the data.
Postby Anthony on Wed Aug 30, 2023 3:15 pm
Is there anything else configured on CAN 2?
What brand is the TPMS?
You can post the protocol sheet here.
Anthony
Postby Leon74 on Wed Aug 30, 2023 10:08 pm
Thanks Stephen, for the prompt reply. I will contact Motec Europe.
Anthony, Yes, there are many other devices on the CAN2. They are locked, so it is difficult to identify what each one is. The brand of TPMS is TireMagic. Attached is the protocol sheet.
Thanks,
Michael
race car New Programmable CANBUS protocol for racing car tpms20220712.pdf
(752.21 KiB) Downloaded 655 times
Leon74
